Spider
I spent the morning, and wore out many blades, trimming the spider flanges.
I used an elevated disk to measure the distance on the flanges. To avoid the flange fillet, I cut out some circles in 1/4” plywood with a hole saw and glued them together. Then stuck a marker in the hole and rolled it along each flange. The picture shows the bottom side of the disk stack.
It worked well to get nice even cut lines.
But before trimming the flanges I decided to move the wiper mount. I cut the mount out first, then used it as a template for cutting the other side. Spring clamps were used to hold the pieces in place while applying glass mat to the underside. Once that was hardened, I mixed up some epoxy with glass fiber powder and filled the gaps. I will likely further reinforce the mount before installing the motor.
After that hardened, I went work on the flanges. I wasn’t planning on trimming the flanges at this early stage, but to fit body panels requires that the spider be propped up to fit the windshield, and if reshaping the spider to fit the windshield, then it should be in its trimmed state.
With the flanges trimmed, it was time to trial fit the glass. I first made sure the spider was flush to the dash deck. All it took was one screw in the center to hold it down and clamps at the ends. I laid out some pillows for protection and fit the glass. Not even close :-(
The inside edge of A-pillars are bowed slightly inward and the sides of the glass curve outwards quite a lot. The pillars match the doors, so I decided that the glass would have to be trimmed.
It will require removing at least 3/16” on the PS and 1/8” on the DS. I’m about halfway way done after four hours of sanding. The high spots are getting longer so I expect another five or six hours to finish the job.
I am using a belt sander with 80-grit. It’s really important use light pressure, take lots of breaks, and switch from the left to right sides to allow the glass to cool. The sander’s belt path has to be in line with edge to avoid chipping. Belt sanders are heavy by design so holding one up for more than a few minutes is difficult. The sander also has to be twisted as I go up and down the side of the window because the curve of the glass changes from top to bottom so a bench mounted belt sander is not an option.
I still get little chips on the edge corners. I feel it is best to sand those smooth with 320-grit to remove stress points before each windshield fitting attempt.
I might have to remove another 1/16” to 1/8” after getting the edges to match because the windshield also needs to move up for an even top and bottom gap. Mama said there would be days like these
