Re: Stephan's SLC Build Threat
Hello Howard,
I do appreciate all the information you provided. There is sooo much to think about.
I purchased a Graziano V8 with the kit which is quite short. I considered it the more economical version down the road. The V10 was 3k more and still not that much longer geared. I thought the money is better spend on a drop gear set matching the motor characteristics when I know what I want. Also I have not decided if I'll track the car. My tires are 26.5" OD. I think the final drive in the V8 Graziano is around 3.44.
Cheer's
My thoughts on gear ratios.
First you will need to decide the final drive. This all really starts here. I would recommend a 3.3 - 3.5 final for a duel use 5 speed car. You could go a bit lower if you have a 6 speed. 3.2 maybe and set 6th as you freeway gear. Track only car will work best if you figure out the top speed you will need. I used 170mph for mine. You should ask other open track guys in you area or intended track or tracks what they would recommend. But 170 is very fast and most tracks just don't have those speeds. So I will assume a 3.44 final and a 28 inch tire as I proceed. Things are rounded here to make it simple. I will link a good gear calculator at the end.
1. Ff you intend to drive the car on the street and in traffic then 1st gear should be selected to start the car from a rest at traffic lights without a lot of clutch slipping drama. A lower gear here is also very useful for crawling around the paddock and getting on the trailer. 2.8 to 3.0 will work well here. Don't keep lower 1st's such as the 3.5s in the Audi's and the Porsches. Its worth it to change them in my opinion. I did and used a 2.8 for first.
2. If you intend to drive hours on the freeway. Pick a freeway speed, 75 is a good one for me, and a engine rev that suits the engine as well as other factors such as cabin noise, etc. Then select top gear, 5th or 6th, to work for you.
3. I have a 1.73 2nd and it is the go to gear under 70mph, abet still gobs of traction issue at anything near full power, (500hp in my SLC and about 350 in GT40)
4. 3rd and forth. First 4th gear should be 1 to 1 and will get you to about 140mph with a 6500 rev limit. On many tracks this will be your top gear. 3rd will, believe it or not, will be your down shift gear for slow corners for just about all the corners at most tracks unless the corners makes a 150 degree or more direction change. Really at most tracks you will do the whole day in 3rd and 4th and be just fine. Mine are 3rd 1.73 and forth .98 & 1 to 1.
So dual use car.
1st 2.7- 2.9
2nd 1.75
3rd 1.38
4th 1 to 1
5th Only .85 (this about 2900 @ 75mph)
5th with 6th .89 (this will be about 3k on revs at 75 mph)
6th .7 (big top speed number but would be a great cruise speed, noise, fuel number etc.)
http://www.tremec.com/calculadora.php
Hello Howard,
Cheer's
