this week end work, trim of the hoods as close as possible to the pin receiver, but i nee low profile head to confirm first.
I also started the headlight installation, by gluing with epoxy glue the fiber glass pieces. you can see in the picture, the fiber glass pieces were not numbered properly and it took me some time to figure it out. (1 was the 3, and 3 was the 1).
My plan A was to mount the light directly in the fiberglass, but it didn't feel right as the adjustment screw brackets were not sitting properly and easy to pop out and fiberglass broke
Plan B: struggle to cut aluminum brackets
(nothing cut aluminum easy in my garage), mount the lights on the brackets and then rivet the bracket on the fiberglass (in case I need to move it to adjust the position). Overall it is pretty sturdy and easier to center the light with the bracket on the fiberglass pieces before riveting.
Also very hard to align the right side light due to the body fiberglass shape, the light is angle (rotation) a couple of degrees, I could not get the "bottom" exactly at the bottom, even after trimming so much on the light.
first look:
