I would reconfigure the stainless braided line from the valley cover to the oil separator. It shouldn't be in the shape of a U. Oil will eventually accumulate at the bottom of the U and seal off the passage. It should be on a slope so that oil that doesn't make it to the separator can drain back to the valley cover. Just my thoughts.I relocated and reconfigured the crank case oil separator and added the transmission vent to it.
Thank you Ken,I would reconfigure the stainless braided line from the valley cover to the oil separator. It shouldn't be in the shape of a U. Oil will eventually accumulate at the bottom of the U and seal off the passage. It should be on a slope so that oil that doesn't make it to the separator can drain back to the valley cover. Just my thoughts.
Hello Joel,Stephan, a work of art. Just beautiful!
Yes it does. Here is a diagram of the inside.Does that thermostat have a bypass circuit?
Ron
Thanks Ken for answering this.
Stephan, that's the same one that I have. Note that Daily spec'd a -12 for my oil line and the female threads on the thermostat are only -10. I called Improved Racing and their -12 male fitting provides an unrestricted 0.60" which is 0.02" larger than a standard -12 AN straight hose end.
Hello Scott,Stephan, that's the same one that I have. Note that Daily spec'd a -12 for my oil line and the female threads on the thermostat are only -10. I called Improved Racing and their -12 male fitting provides an unrestricted 0.60" which is 0.02" larger than a standard -12 AN straight hose end.
