Mo, It came from Lowes.
Off the top of my head: If the tip of the tube that extends into the overflow tank is higher than the lowest point in the coolent system (water jacket in block) then it should work.
I am using mine as a catch tank, only to prevent overflow being pumped onto the track.
10 0z is pretty small. I wouldn't go much smaller than 1.25 quarts. Mine is 1.75 quarts. If I had more room I would have gone to at least 2 quarts.
Anybody?
McMaster Carr # 5431K17. Poly insulation with 1 5/8"ID. Its for indoor use but can be used outdoors with additional jacketing. ...#K16 is 1 3/8"ID not sure if it will stretch enough.
I think it is very necessary. All that heat is going to be soaked up by the alum chassis rails and they are going to be at the water temp in no time. The best idea is to keep as much heat inside he tubing as possible. This car is going to be hot enough inside without adding to the problem.
I think the foam insulation might be 1.25. I seam to remember stretching it a little before I glued it together.
