I can measure the length of the welded spacer as well if needed. I would have already but found my micrometer battery dead...lolThanks Ken, you rock.
BTW: A friend has found your Corvette forum posts very helpful in regards to his Z06.
Please do measure, I can send a battery up if needed![]()
Thanks Joel.
Here is what I have so far, since I have no current gen chassis to reference I appreciate the input I am getting. It appears the frame rail should be 60 degrees off the connecting "vertical" chassis beam (confirmed?). Joel, could you give some reference for the distance from the top of the vertical beam to the top side of the bellcrank rail in some fashion? Trying to confirm locale of this part vertically may be difficult to communicate.
Again, thanks in advance.
