Graziano Transaxle Installation
PeteB
Fran,
I received the cable end for the ball connection. Is the end for the other cable coming soon?
PeteB
What oil is used in the Graziano? Smells like it has friction modifier in it.
How "full" does it need to be? The only place I see to check the fluid level is the fill port - doe's it need to be full to the top?
Certainly you can fill the transmission from the side fill port. You don't have to use the top. Four quarts is about all it handles. I mentioned this information in my build. If the search function worked here then you could find it.
