Hi all,
I am about to route the feeding cable to connect the alternator and starter motor to the battery.
I'm having a hard time coming up with a good way to route it though, since it shouldn't be routed close to other sensitive electronics.
Is there someone out there that know of pictures of neat installations to show here?
Maybe routing around the oil pan/block mating surface?
Should mention I got the alternator on the driver side up high, and starter motor on passenger side down low. Battery is located in the passenger side sill.
