Chevron B16 Replica
Dave, Looking GREAT! Keep up the progress, as I'm living vicariously thru you while I wait to get my build started. Not a B16 but it's always been a personal favourite.
Terry,
I went with 24 gauge steel (.022) instead of aluminium. Just to add a bit more strength. I 'm not too worried a bout weight. I am keeping the metal thicknesses the same as the oringinal.
Dave
Dave
trying to get some scale here as it relates to a project I am considering. What is the width of the sheet metal floor?
Dean,
That is a 4'X8' Sheet of 24 Gauge steel. I had to trim two inches off the lenght to meet the 46" width. I lined it up and scribed it to the floor of the chassis. My buddie Al and I cut it on my chassis table with a mini sheet metal cutter. I bought two sheets and second one I cut into three pieces so I could handle it by myself to do the rest.
Dave
Gent's,
Had a warm day today started panning the front firewall. I will spotweld it in place tonight. Now back to getting dinner ready.
Dave
Winter Intermission (Friggin Cold)
Gent's a few pic's of the bodywork before I purchased it.
Dave
Russ Noble
Russ when you get to the track ask your nemisis B16 what spring rates he is running. I have a good idea what to use, but a healthy start would help.
I spoke to Murray at the weekend at Teretonga where he lowered the Classic sportscar lap record twice. That thing just sits so beautifully on the track and the FT200 keeps the motor in it's sweet spot. Sounds fantastic too. But I digress...
Spring rates are 350 lbs/in at both ends. He says don't be tempted to go higher.
Cheers,
Russ
Russ,
Thank's, I was bang on for the rear but thinking a little lighter in the front. That helps alot. The car uses a 6" spring on a Koni 8212. I will probably go with QA1 the Koni's are out of my price range. I see Murray has not sold it yet if he is still running it. Next time you see him tell him "Thank's" from me.
Dave
I realy love this car. One of the most beautifull racecars ever built.
looking at your frame i wonder if the torsional strengt could be increased. espcially the connection from front to rear via the sidepods is not triangulated at all.
I modified the pic according to what i would do. I´m shure it will help alot.
If you have access to cadia or solid works you could draw it that way and let it calculate the difference.
Hope not offend you
TOM
Tom,
No offence. I still haven't spot welded the rest of the sheet metal in place too cold. The footwell area and across the top of the sidepods. The back firewall and the backs of the sidepod and inner wheel well. I put two extra braces in the front in the foot well area like the B19. They used aluminum instead of steel and pop riveted to save on weight. I did it for safety and extra strength with the use of the steel. I have an Escort mast jacket I have been working on, also Conrero Monte Carlo 320mm steering wheel with Ford adapter and hub. I have been working on the harnesses because the wrecker cut most of the connectors off. I am separating all of the curcuits. headlamps ,turn signals R&L,wipers etc.
Dave
David
Aaah, ok makes sense and should be enough
on most of the pics of the b16 the rocker panel is alu and riveted on.
What´s your plan ?
TOM
Tom,
I plan on using aluminum on the bottom of the side pods. I substituted steel on the floor pan only just to give it a bit more strength. I have done most of the changes that they did to the B19 chassis over the years, but still using the same old build process done for the B16. This chassis is more like a semi-mono than spaceframe because of the spot welded panels. Strong though. I will keep plugging away.
Dave
Tom,
The two verticle 4" x 1.5" tubes on the back firewall (recievers). The verticle tubes are raked back about 15 deg at the base. The two braces to the rear shock tower come off of it. I have a picture of Bobby Rahal standing in front of his chassis at the back that shows it. I will have to e-mail Kelvin Jones to see if I have permission to use it. They were published on Kelvins site. You will have to wait until spring to see mine.
Dave
