Hey there everyone, I’ve done my basic alignment using a Hunter system and have quite a bit of experience doing them. What I am essentially looking for is a discussion or experience comments on the specs you used (mostly for street use) and tire wear. If you have an Active Power chassis, even better but don’t think the different replicas will be drastically different. I have used both the 2005-6 GT specs as well as the Corvette C5 to compare specs but I’m using Prothane bushings on all the control arms which would drastically change the flex compensation in the alignment specs from a stock rubber suspension. In the end, only time and experience will tell me if other adjustments will be needed but want to start with something close.
I am using a manual rack for steering with a front sway bar only at this point and have set the ride height for all four corners to about 4.8in (122mm) which is very close to the original spec. Right now front is at 0 Total toe/-.1 degrees camber/ -2.3 caster and rear is 0 total toe/ -.2 degrees camber.
Anyone have theirs I can compare to? What has worked for you?
Devin
Devin
