Yes, that's the one. I'm not sure what range of motion your throttle plate makes, but its less then 90deg. So a 100deg measurement range is good enough, allows you for a bit of a range of motion with high precision of voltage output.
Can you share a picture of the TPS mounting without the TPS installed? We need to be sure that Jenvey hasn't gotten a unique D-shaft orientation when throttles are closed. They can do that, and would mean you'd need a custom programmed TPS sensor. (Or buy directly at Jenvey)
store.jenvey.co.uk
TPS Contactless - L&R
A motorsport contactless hall effect throttle position sensor with a Deutsh DTM connector.This sensor has been designed to opperate left and right hand depending on how it is wired. Wire ConnectionsPin 1 = Signal 1Pin 2 = Power +5VPin 3 = GroundPin 4 = Signal 2 TPS Loom Socket is sold...
