And so the the body, perhaps the bit that daunts me the most but so far it seems ok, few pictures below and as always tips and tricks welcome.
So I popped the clam shell on, got it centred roughly back and front, did notice there is a 10mm overhang on the passenger side for the scuttle as per the images below, the driver side is flush
So I left as is, the screen seems to fit really well with even gaps and it sits snugly onto the clam without any gaps.
On a roll it was front clip time, I have mounted that and it seems pretty good, I have got it centred on the tub front and back and the distances from each hub are within a few mm, I guess ok for now??
My gaps at the doors don't seem to bad either, passenger a little tight but I moved the clam over a bit and that helped without raisng the screen too much
So going I hope in the right direction.
Clam hinge next, anyone got any idea which way round it goes? Its a bent tab and I am not sure if the bracket faces forward 9thats what I am guessing) or backwards.
Also I could do wither a measurement of how high the clam sits at the nose, or do you do that with a circumference on the hub so the wheel sits right? Time for a cardboard wheel maybe??
Final question, how do you beef up the bracket where it bots to the body, is a spreader plate on the inside where the light box is enough?
All done for now, may try the rear clam this weekend, what can possibly go wrong
