So it is final, headlights are going the way of the wind. They were not going to be dot compliant, which obviously wouldn't work in a product atmosphere, but could have posed a problem with titling the car.
After many weeks of searching for just the right dot/sae headlight housing, found that Hella makes a 60mm sealed projector (original ones are 90mm). Unfortunately, you have to have 4 of them since they do not have a hi/low combo projector.
Design process has begun, and projectors coming in tomorrow. I am 80% sure I will be doing an install similar to how the Pagani's and TVR's and FXX install them with no lens cover. It will really clean up the molding process, and eliminate the need for a separate lens and worrying about how to fasten it.
On my searches though, I did find other suppliers for led and hid small dot projectors, but price is a pretty good commitment. They could be optional though.
Pagani with our original 3.5" style hellas
Zonda R which appears to have the 60mm ones
TVR Speed12 with 90mm
Fxx which appears to have a custom dual hi/low housing, but scale I would guess to be a 2.5" (60mm) lens.
Pretty excited about this. Easier, cheaper, less time for mold and install, plus taking a styling flare from some of the most beautiful cars in the world isn't all that bad either!
