I would get the Mendeola sequential over a graz. Easy to rebuild. Way more gearing options. And the dudes support the component car market.
My head is now spinning trying to crunch all the 'total cost' estimates /assumptions represented by the various available engine/tranny combos mentioned above in the attempt to come up with a clear cut winner!
Having tried that, I remain convinced that, from a total $$$ standpoint (not to mention the advantage of not having to address a possible trainload of 'unknown variables' and Murphy's Law-generated 'pitfalls' that could spring from same...as well as the extra time that will likely be spent dealing with each/all of them), the Graz is the simplest, easiest, least 'complicated', potentially least 'consequential'...and most cost effective way to go overall.
Buuut, hey...admittedly, I'm not the brightest bulb on the Christmas Tree...so... :sad:
Brilliant!
Following along with popcorn in hand....
Does Speedriven make stand alone ECMs for Mercs V12s that are no longer in Merc chassis?
Repeat...
Scott = bad influence. Scott = bad influence.
...So, headlight design number 5-6 might be coming soon...
I prefer to call it "perfectionist"!![]()
..."a vehicle is never truely done, it just gets sold!"
Is 1500HP at the wheels enough clutch?
Tilton Triple Carbon Porsche 996TT Street/Race Clutch
You'll shoot your eye out kid.....................
Will keep rocks from hitting the back of the panel...
Have you pondered spraying on a coat of Line-X or equivalent to 'cushion' rock hits a bit?
