Gallardo Mesh
You are a brave man.
Once you get them apart I cant help but think its just another car, nothing high tech.
The fire wall you cut out are you going to put back a strong structure to take its place.
Jim
Jim I could use this gallardo as Original but it's for me a project more than just a Lamborghini I am trying my best to reach at least 70% of what I am thinking
It's engine , transaxle , twin turbo , interior and exterior project
For the fire wall yes my friend it was 2 cm the part I cut and I bought 8 cm plate
By tomorrow I will upload how I close this part
I started prepare the plate to close the firewall
I bought plate of aluminum 8 cm which is thicker than the
OEM ( only 2cm)
attachment.php
you can see how is thick than the original part
attachment.php
because is too thick I need to send the plate to special company with my measurement to do it fit the firewall
attachment.php
we just set the plate to see how it will look like
attachment.php
I faced problem with the seat , it was touch the box from inside so I take the box and cut it again from the top , see the picture from inside
attachment.php
here is the free space I have after moving the firewall , its look good now for the engine to install
attachment.php
I decide to do aluminum argon welding for the whole box with the body
for the tips and closing inside the box from out side and inside too
attachment.php
from the inside
attachment.php
also I will install roll cage but after I finish the engine and transaxle to start working for the interior
David I was going to make a hatch but the Garag told me , after removing the 4wd shift
That's it can be easy to reach front of the engine from down we have free space , but honestly I am not sure because still didn't install the engine yet
after closing the firewall with thick aluminum I was thinking how to avoid the temperature , noise and the sound
I have no idea if the any of the three will reach the car from inside so I decide to have three layers to be sure that's the car from inside don't bather me specially I will have for street daily or three time a week
the first layer was 3M
attachment.php
from inside
attachment.php
the second layer is non-flammable and sound and temperature deeding pads
attachment.php
attachment.php
the last layer was he jacketing roll
attachment.php
those layer only will be for out side ( the engine side )
and I will have more from inside the car
starting with the 3M layer pads
attachment.php
attachment.php
I did it just for the center but after that's I open the OEM pads from the two sides and have 3M one it , you can see it here
attachment.php
continue with the pads
here is the second layer on top of the 3M pad
attachment.php
attachment.php
after finish the layer two pads I start wear the pads with the jacketing roll
attachment.php
attachment.php
that's it three layer of pads plus the two side OEM pads and I will have the OME parts for the gas tank after install the gas tank
attachment.php
I added 3M paste for the tips over the jacketing roll so just incase I will not have any issue with water or any things else between the three layers
attachment.php
after that I wash the car with water pump and air pump plus ACDelco cleaner
attachment.php
attachment.php
you can see the different between the two pictures ( when I found the car and after )
attachment.php
waiting for what is next !!
attachment.php
I received the transaxle harness from italianknightrider and it was with good condition and labeled ...... thanks
attachment.php
here is the engine harness I ordered from Painless with extra length
attachment.php
now I start thinking what color I will go with , I like the gallard super trofeo
color so I got the color code
attachment.php
attachment.php
Great colour choice, and what an amazing difference a good clean makes it looks great... Will you be fully respraying including the engine bay etc?
Interesting project there. Looks like a good challenge.
If you don't mind me asking, why didn't you want to use the Gallardo engine?
That firewall looks like it's a pretty structural component of the chassis...considering the wall thickness. I can understand the desire to have access to the front of the engine without having to remove the engine....that just makes normal sense. Are you planning on making the part you removed a bolt-in/bolt-out access panel for ease of servicing?
Paulbav .......this is what I am planning to do right now I don't want to respraying the whole body now because I am still working on engine and the body , on the other hand if I install the engine I will not be able to respraying the engine bay
I think I will just do the engine bay and install the engine with the transaxle then whenever I finish the body I am going to do the whole car
cliff beer ...... its more than one reason
here in my country only 5 or 6 garage can work properly with this kind
of car ( Gallardo engine ) moreover they are using this situation and its difficult to find used part we mostly ordering from the internet even the shipping is high cost for us , last thing I want to have the engine with twin turbo around 600-700 HP
this goal is cost me a lot with the original engine ( see the underground cars )
and who will do the programs for me ,I have to send my car to usa !!
for the bolt-in/bolt-out yes I am planning but the garage guys told me wait until we install the engine then see , they believe that's we will be able to access the front engine from the down of the car ( where was the 4 wheel drive shift )
I really like the design of the this car but unfortunately I sent to them many emails without response , some one told me they close the company and they are not doing this kit any more :(
I contacted more than one person who work with 3d CNC one or two of them agree to do this kit but with high cost
finally I found one guy can do this rear view with good price
attachment.php
attachment.php
after deciding to go with this rear view I started looking for the equipment for it , I found this grill for sale
I bought the original grills because it so difficult to make it replica
attachment.php
here you can see how the grill has different size and not straight
attachment.php
also I found the rear light with good price and good condition
attachment.php
by contacting one guy from different site , he was able to do the rear tip for the grills and the exhaust tip
exhaust tip was made by fiberglass with correct measurement and I have to take it to build it by steal whenever I receive it
attachment.php
the rear bumper still working on it plus I still waiting to receive the rear grill tip and exhaust tip to finish
that's it , I am standing here right now
my project has big change , i have on of my friend want to buy the my transaxle with the harness and i decide to add twin turbo to my engine
so in this case i have to go with transaxle can handle my high HP
i ordered 01e transaxle from advanced automotion with some upgrade
i suppose receive the transaxle next 10 days
also i order the adopter with the cable shifter from Eric
so i have to wait until i get the items to start working again
