TY for the input. I will look over those options... amazing technology no doubt.
Fran expressed concerns about my rear wing mount connecting to the bar under the hinges (the bar connects to the hinges), and not connecting directly to the chassis. If the forces were directly transferred to the chassis, that would be better.... So, here is what I came up with...
I had brackets fabricated that are bolted directly to the rear hinge/chassis. The vertical uprights are extended to the new brackets. This is very rigid. The upper "U" shaped bracket that I previously posted (which tucks under my cold air box) will be mounted to provide even more lateral stability. I also extended the height of the vertical uprights to set the wing slightly higher.
