The threaded inserts look like Riv-Nuts rather that Nutserts.Bonnet, Underside Panels, Part V
The screen is another dominant feature. Looking at photos of originals, there are notable variations in the manner they were secured. We opted to make a frame, consistent with one prototype, to give a more finished look. As usual, a pattern was made to confirm the dimensions.
The screen is supported by angle sections, ¾ inch on each side. Nutserts for 6/32 SS screws will make attachment of the screen straightforward.
The frame around the screen was cut from aluminum. Note the screen is set forward an inch within the opening, similar to the original. The screen material is aluminum with half inch spacing. It came from McMaster-Carr, part #9227T52.
The D Type has rubber panel seals in certain locations, sandwiched between strips of aluminum and held together with rivets. Brass rivets can be seen in several originals. Just for fun, we added rubber seals around the carb air tunnel.
For now, most of these panels and brackets are held in place with clecos. Once the inside of the bonnet is painted, they will be permanently installed.
Riv-Nuts were developed by BF Goodrich back in the 1930s as blind threaded inserts for sheet metal. They are placed into a drilled hole and a threaded tool is inserted and pulled tight, flaring and expanding the end of the Riv-Nut behind the panel. The tool is then removed and the Riv- Nut is ready for a fastener to be threaded in. The fastener can twist the Riv-Nut in its hole if it is over- torqued. Some special types have been made with key ways to prevent twist but they require a special punched hole, not a simple round drilled hole. The rear expanded bulb prevents the Riv-Nut from pulling out of the hole.What’s the difference between?
