If you can draw a bananna in sketchup, you can draw anything...
If you lay off of the vodka it won't be ketchup.
Words to live by. Was that Socrates...or Confucius? :laugh:
Thanks for the help with Sketchup Yos and everyone else!
Yos, was it necessary to have the G96.50 trans beefed up to handle the torque of the LS9 or is it capable enough in stock form?
Also, does the height of the supercharger interfere with the rear window? If so, what is your plan for this issue?
Some coolant line pics. I used header wrap on the side pipes and I think I'm going to use the flex hose to go around the front wheel area. It's either that or welded pipes.
Mounted...
I was just trying to keep as much heat out of the passenger area as possible. I figure that was the case but I was not sure. Have several builders said anything about heat build up issues?
I've since removed those coolant pipes all together, and went with welded aluminum pipes all the way from the engine bay to the radiator. I am sure it looks much better. It sounds you are like me in the fact that fit and finish is important to you even if the detail is hidden from sight.
Thanks for the link...I actually looked for 1.5" ID sleeves, but couldn't find any. I am not 100% sure on the quality of the product from that company as I have never seen there stuff in that size. I know the bigger stuff is hard to find, you may want to call them and ask them for a small sample or at least a good description of the product.
My old lady was pretty pissed off that I used her good salad bowl to soak it in... Ha thats nothing, you should have seen my friends wifes face when she came home to find his dirt bike gear on their bed on her nice white bed spread. That was at least 8 years ago now and I still remember her face and her yelling his name at the top of her lungs telling him to get his butt up here right now. Those kinds of moments are such good comedy. He is still alive and they are still married.
I may use that sleeve on the new pipes, but at $8 a foot...ouch! I really hate when I want stuff... :veryangry: I figured you might say that, sorry for your luck but I know how you feel!
And I have my steering wheel finally. The PRI Show in Orlando was a blessing...it's so helpful to have 100 steering wheels all in one place, where you can actually put your hands on em'
I'm going to use the kit supplied QR and re-drill it for the Momo pattern. The distance from the column works out perfectly, and there's not so many different parts this way.
Yos - do you know what size wheel and model number that wheel is.
Hey Mike...it's a Momo Mod 30. I believe it's 320mm. It's small, but not much smaller than the supplied one. May even be the same size. Feels just right in my opinion...
I've just spent about 1 hour looking at MOMO wheels - got it narrowed down to 3 models and then the Grant 4009 adapter. It would be nice to have all three here to try....damn.
I have to stop frequenting this forum.... it makes me buy stuff.
Yos - Did you bend and weld the coolant lines or did you have a shop do it? Very nice work either way - exactly what I plan to do with mine.
