The following is a qoute from J Salmons thread " Driving Impressions of the SLC".
I want to be completely critical of this car. It does no one any good if we just stand in a circle and hold hands and sing songs about the SLC.
This car is a prototype, and so has some roughness to it. I will go on about that more next post. One thing to be sure of is that you address the heat. It was a hot day for sure. The SLC windscreen is a work of art (it is my favorite bit on the car). But it also directs all the air away from the windows. So even with them removed, you will not get any fresh air into the car. I don't think you will get any water in either, provided you are moving. You have to stick your hand out the window a good 4-5 inches before you feel any breeze. Plan for some vents.
AIR CON is essential, if you ask me. Just pretend it is a LeMans racer, and realize that it is required. (Closed cockpit cars require it. Now the open top version...)
The engine is behind you. It gets hot. The cooling tubes get hot. This car does not have adequate heat barriers between the firewall or the cooling tubes. In 20 minutes as a passenger my right foot was pretty hot, sitting right next to the cooling tube. The footbox was clearly heating up. The engine heat was also slipping into the central tunnel, and we think this was responsible for heating up the stick shift lever. In 25 minutes it got so hot that you really could not hold it with your bare hand. Again, seal it up really well.
Plan on spending time addressing heat. This is not a new thing, and it is not impossible to tackle. But many cars in history have had too little attention paid to this area and have suffered for it. More on that next post too.
