Ross, As pointed out earlier, anything you can do to reduce that figure will help. Some suggestions;
1., If you intend to persevere with the current upright consider some hubs that have the stud face closer to the upright/ and if possible move the rotor closer to the upright to facilitate that. This will also mean remounting your calipers---- once you work out the financial cost in time etc it may be more beneficial to simply obtain some uprights along the lines of those shown by Iain or Frank.
2. Changing the sizes of your Inner Outer rim halves to decrease the offset-- bear in mind that you have to maintain running clearance for your Caliper / Rotor and that there is a greater chance of fouling the w/bone's & tierods with this change.
3. All of these efforts to decrease offset means that you will need to fabricate new longer wishbones to reinstate the original track width.
4. Dont forget to check your wet rims for arch clearance with these mods as with the hub face now being out board from its old position they will be closer to the wheel arch.
Jac Mac
Jac Mac
