Trevor Booth
Now that got everybodys attention 11º is correct. (-7.5- +.5-3=11)
For the advocates of 10º (alt 167 pressed slowly)
The KPI is 7.5º with a positive camber of +0.5º
Increase KPI by -0.5º (ie 8.0º) the static camber is then zero add three more degrees of neg camber the KPI is 11º
Now given the KPI 7.5º bench measured by Ross N with effectively no camber.
Installed KPI = 10.5º
Ross N put the car on a wheel aligner. Then you have a known basis to work from. Whilst on the aligner note what adjustment does what.
say, 2 turns in on the top rear wisbone rod end = change in castor = change in camber = change in toe in. do the same for camber change/toe in change. You can then make in the pits adjustments with some degree of accuracy. It is also a good idea to square the car up with 0 camber and 0 toe in and then set castor camber toe in / or out as the case may be.
Have you checked the wheelbase Right and left ?
Scrub radius- project a line to the floor thru upper and lower ball joints. Drop a line down to the floor from the hub bolt face. ( hold a straight edge across the bolt face , not a vertical line) measure the distance (A) between the two points. Then measure wheel offset and add to (A)
Car must be sitting at ride height
Tim, working on doing an RF plot
Russ N , no I was not being that cryptic but I was confusing the issue with the +5º static
