Suspension parts for gtd mk1
Malcolm
the original GTD bushing were the rubber silent block type of bushing. If you wish to replace, either convert the arms to take rose/heim joint or talk to aftermarket bush suppliers and get some polyurethane bushings to fit. The latter is the easiest option and well worth it.
Mike Pass
The GTD chassis were constructed by GTD. The front uprights /brakes are Ford Granada MK2. The rear uprights are sheet steel made by GTD and use Ford Granada Mk3 hubs/brakes. The original suspension bushes were rubber as Malcolm said. Best to change to polyurethane type.
