Tim Kay
Frustrating chain of events always lead me back to you guys with results that usually have me scratching my head saying "why didn’t I think of that".
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
</o
I recently installed a new set of rear calipers & rotors to my already upgraded set of front calipers and rotors. In addition, I did away with the brake boosters and installed a new pedal box with top mount bias pedal - dual m\c (with 7:1 pedal ratio)
<o
></o
I have no pedal resistance first third of pedal stroke and "spongy" resistance on remaining pedal stroke (at bottom of stroke it gets a bit firmer).
<o
></o
What I have done:
1. Bench Bleed – more than once
Final bench bleed I capped the outlet and get a rock hard pedal immediately upon very short pedal travel (leads me to believe there is no air in the m\c)
2. Numerous caliper bleeds (nary an air bubble).
Typical procedure: two person, pedal pump, open bleed screw, ect.
Vacuum bleed
Power bleed at the m\c, out through the caliper bleed screws
3. Isolated the two m\c to operate one at a time.
Went through the bleed process
Tried to at least get one set of brakes to get a hard pedal, to no avail.
4. Residual valve installed on front brakes only.
<o
></o
<o
></o
Below are the caliper piston sizes if anyone can do a quick calculation:
Front caliper (6) piston diameters are - 1.62/1.12/1.12
Back caliper (4) piston diameters are - 1.38/1.38
Are my ¾” m\c too small? Do I need more volume from the m\c for the piston size I have? Any suggestion?
<o
<o
What I have done:
Vacuum bleed
<o
<o
