I started with the rear clam today, made a steel frame in 20mm*20mm tubing. Added two more mounts on the lower factory steel tube, and four mounting plates further up.
It might look a little overkill, but I`m planning to remove the "bumper" part of the clam and have the diffuser mounted separatly, just haven`t decided yet.
The frame was mounted in a bed of FG bondo, that way I don`t have to be too acurate with the fit of the mounts.
Got an idea last night when my "sunshine" was baking a cake and sprinkled whipped cream on it, I thought that plastic bag sprinkler could come in handy, so I gave it a try and it worked fantastic.
In stead of putting the bondo on the FG and then placing the frame on it, I installed the frame first and then pressed/sprinkled the bondo in the cavities in between the frame and clam. It goes much faster that way and you don`t have to risk the bondo starts to cure before you`re done.
Next up will be the rear lights and the rear electrical harness.
I have also made a new forward hoop for the roll cage, it is 3"/ 75mm wider then the factory, more of that in the next post.
