Porsche 908/910 project
Woowwwwwwwwwwwwwww
Martin those rear lights are EXEPTIONAL !!!!
These are a sample of parts to source to match to originalones and I have to admit that Martin is an "superextra sourcer man" !! LOL
Thanks to him we found rare items like the front orange smal indicators light and front headlights matching to front bodywork space !
As I was not able to succeed in sourcing( as Martin did)original Hella rear lights I had the opportunity to found similar ones from "tractor stuff" ( Chris should know these hé hé)) and with a machined alu part they match not so badly
This is also part of the fun ; spend some long hours on the net !!!!!
Michel,
Very Nice build, and very nice car also, even if I prefer the 906 shapes...
I tried to send you a PM via this board. Unfortunately, I never received any answer. Sad, as I could have pointed you where to buy the same rear lights... here in France, as did Chris.
Regards
Olivier
Hello Chris
I notice you also spend all you"harvested money" in that crazy site LOL LOL LOL
side indicator lights are easy to found as they are still in catalog at some supplier in germany sourced by Martin
Otherwise the more rare to find it is the numerous hours ( and Chris you know what I mean !!) of welding all tube one together ; the fact is with the very accurate 3 D drawing all lasercuts are superb and there is nogrinding at all just tackweld and then welding , welding , welding
The result being so nice afterwords you forget all these hours and enjoy to have aso rare frame !!!
If I get some free time Iwill post if any interest the wip of what was the frame welding evolution.......
How chassis started in december 2012 ;
Hello Chris
Thanks for your comp....
Yes they are done in TU 37 b cold drawn noweld and each end of tbe is slightly engraved laser with number of tube to place it correctly following the 3 D drawing ( same as Marcel and you did with your 917 chassis I guess)
More or less there are 157 different tube to assemble plus the surround of windscreen ( this one is to be done when everytube have been located and the bodywork centered on in the correct position
This is when surrounding tubes where bended and grinded to match to bodywork as closely as possible because when the chassis is achieved and fully paited then you need to laminate both frame and some areas of bodywork
Hubbs , front and rear suspension ;
This week start of bonding and laminating all panels to the chassis ;
Just to help out a little bit Jacques, here are some pictures of the tail lights he had reproduced (plastic injection with metallic molds!).
He had some issues with his last production batch and endend with various quality parts.
So he decided to make 3 categories depending on the level of correctness of the lights:
Perfect ones, good for "Pebble beach" are priced @800€/pair (no pics)
Small defects, mainly on the chromed bezel: 500€ a pair they are shown in the two first pictures
More defects, may be either in injection and chromed bezel: 250€ a pair, , the two last pictures.
I have no interest in this business, other than help out other Porsche nuts! I had a pair of perfect ones in hands, and they are awesome! And when you know how difficult it is to find an original pair, this is a very good option!
Precision, prices are ONLY for the plastic lights. Jacques also sells the base and seals. The best way is to contact him by PM...
Long process of triming and fitting corectly all internal panels and then bonding these plus finally laminating strips of clothes to rinforce those "composite weldings"
Hello Fred
Ho yes indeed "fiddly job" !!!
By chance am lucky to get help from my nice wife.
Am jealousing GT40 guys riveting their 2500 "pop" rivets !!!!!
I am using one matt 200 then one or two roving 220 gr stripes already sawn on sides ( these can be sourced in rolls )and finally and 100mm wide or 50 mm stripes of peelply that I strip off day after when cured
Before laminating I apply a"curved chanfrein" of mix of resin low catalysed added with"flocs" to give to the resin an consistance of bonding stuff
In doing this work am using Vynilester resin which to me is much more flexible and stiffer to torsional loads .
Hello to everybody
Some fresh news of the 908 project ; after cutting bonding and recuting etc ( LOL) bodywork is finally fit into the chassis
Qite major parts are laminated around tubes so now will start the long and tedious work to trim doors and then doing a finish on all gaps of different parts of this body
Here's my 3.0SC on the dyno. Early days mapping and setting up.
