How many of you fellows do you own alignment and how hard is it to do? I'd like to learn how to do alignments, not to the 0.01 degree, or even the 0.1 degree, I imagine that 0.25 degrees would be more than sufficient for my purposes.
I need to acquire some basic alignment skills. I have successfully measured toe and adjusted it at the track using borrowed toe plates, and made some eyeball camber changes as well. Too much time, and money, is spent dragging race cars around to alignment shops. I need to be able to check alignment, adjust after offs, and generally be able to make changes when I wish.
What do I need?
Toe plates would seem necessary.
Bubble camber gauge that attaches to hub? Magnetic or hub bolt on?
When you make changes do you try and do it as the car is weighted, i.e., on the ground? This would seem to make sense but can be very hard to do under track conditions with cars that have little or no ground clearance.
I know this is a rather open ended topic but I'm interested to see what folks are doing and how they are doing it.
What do I need?
