Maybe this thread is already there and I simply cannot find it? If so, my bad. I was hoping to find a place that people could post factory options, upgrades, and other parts/things that we as builders have added. it is a thread that builders can go to to look at build options.
Literally the day after I finished modifying my rear clam (I am not using the window) and adding vents into the solid clam along with 2 NACA ducts, i saw the post of the carbon fiber vents available from RCR. Really bummed me out. so as per Will's response, I went to www.public.slc.wiki.
Under "Factory Options" are listed:
Transaxle
Brakes
Interior Tub
Penski Shocks
Track Day Side Impact Bars
Chassis Mods
Turn Key race Cars
Track Day Suspension
Carbon Fiber Window Vents
A dollar short and a day late. :furious:
Oh well... I decide it could be useful if we listed an explanation about our add ons, where to purchase them etc. I tend to get on the forum daily bit I go to the wiki very seldom. So, I felt this could be a good place for everyone to show us your latest option, upgrade or add-on!
Here are a few things I have found useful for my build:
1.A nice faceplate from Vintage Air:
491200RUA 4 knob control panel should work with our application.
http://www.vintageair.com/Instructions2013/904912-RUA.pdf
Knob 1 and 2- wiring that is inside the 2 knobs with the plastic housing
Knob 3- ECV
Knob 4- Thermostat
2. Electric Doors as per the "Master" Allan. Be sure to see his you tube videos on the doors and everything else https://www.youtube.com/results?search_query=zakari+3030 :
39A standard left hand and right hand
5 6960T61 4 Each Super-swivel Ball Joint Rod End, 3/8"-24 Rh Male Thread, 3/8" Id, 1-3/8"l Thread
6 8982K46 1 Each Multipurpose 6061 Aluminum, 90 Deg Angle, 1/4" Thick, 6" X 6" Legs, 4' Length
7 84945K113 1 Each Self-lubricating Uhmw Polyethylene Sheet, 1/4" Thick, 12" X 12" Sheet
[ame=http://www.amazon.com/gp/product/B001FYUYQ0/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1]Amazon.com: AutoLoc LAMB Linear Actuator Mounting Bracket: Automotive[/ame]
[ame=http://www.amazon.com/gp/product/B000CIFNB6/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1]Amazon.com: AutoLoc KL800 8 Function Keyless Entry: Automotive[/ame]
[ame=http://www.amazon.com/gp/product/B000SSYXW0/ref=oh_aui_detailpage_o04_s00?ie=UTF8&p]Amazon.com: AutoLoc MOTORCT2 2 Channel Motor Control Unit: Automotive[/ame]
These are the controllers you need:
[ame=http://www.amazon.com/gp/product/B000SSYXW0/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1]Amazon.com: AutoLoc MOTORCT2 2 Channel Motor Control Unit: Automotive[/ame]
3.Chassis Heat Deflection
Reflect a Gold from DEI
4. e stopp... works awesome. It seems it was designed just for this car!
E-Stopp Brake
5.Accusump
Summit Racing has good prices on them...
6.Oil Cooler:
If using an Accusump in conjunction with an oil cooler, the attached plumbing is recommended. 8AN lines will suffice, but 10AN lines are recommended. It is important that the Accusump "T" after the oil cooler. In this scheme, oil travels out the engine via a low profile adapter from Improved Racing part #EGM-106,
Oil Cooler Adapters | Improved Racing. It travels to a remote 4 port thermostat Mocal OT2, BAT, Inc. - MOCAL Oil Coolers . Oil will circulate back into the engine when the thermostat is closed. This diverts oil from the cooler when it is below 180 degrees. When above 180 degrees, the thermostat opens and oil travels to the oil cooler Setrab 625. It then travels back into the engine. Because the Accusump is plumbed before the remote thermostat, it always carries an appropriate pressure for proper operation. This scheme also ensures that the Accusump is plumbed after the oil cooler.
7. Short Hub for removable steering wheel:RACINGLAB-67298 from Racinglab.com
8. A Simple Dead Man Pedal: From O Reileys
9. Lift Kit- from RCR
Transaxle
Brakes
Interior Tub
Penski Shocks
Chassis Mods
Turn Key race Cars
Knob 3- ECV
Knob 4- Thermostat
E-Stopp Brake
5.Accusump
6.Oil Cooler:
