Gas/Brake Pedals Installed
In parallel with wiring installation, the brake system is also being installed. For that, I decided to start with the pedals and work outward to the disk brake calipers. Given the somewhat horizontal seating arrangement in the Miura, it seemed like a good idea to build some adjustability into the pedal locations for drivers with different leg lengths. The pedals are floor mounted using a Wilwood integrated pedal and master cylinder setup. By mounting the pedal set onto a ¼” aluminum plate and then drilling a series of adjustment holes into the plate, I was able to achieve 3” inches of front to back travel for the pedals. The chassis floor is also ¼” aluminum plate so the combined ½” of plate gives the pedals a rigid mounting.
To keep pedal adjustments as simple as unscrewing four nuts, move pedals, and re-installing the nuts; the throttle cable mount also needed to be anchored to the same mounting plate. After digging through my scrap aluminum bin, I came up with this arrangement. Given the engine placement behind the gas pedal, it’s a straight pull between the pedal and cable to open the throttle plates.
Having master cylinders whose location can move adds a wrinkle into the plumbing. Namely, flexible lines are required prior to the rigid tubing. Here’s what I came up with.
The last piece for this part of the brake system was mounting the fluid reservoirs. My preference for simplicity of checking and re-filling the reservoirs was to mount them on the front side of the front bulkhead. But after fitting a tire into the spare tire well, there just wasn’t enough room left over for the three reservoirs. So the next best location was the backside of the front bulkhead and I’ll need to build in an access door when this area is closed off with sheet metal.
So far the most challenging part of the brake system has been figuring out the multitude of fittings, hoses, and tubing that is required. 3/16” tubing for brakes, ¼” tubing for clutch, adapting between NPT and AN threads, angled fittings, bulkheads, and the need for residual pressure valves because the master cylinders are below the calipers makes for a mind boggling quantity of parts that need to be sourced and procured.
