LS7 dry sump oil tank plumbing
Dave Forster
It might, but I'm really just trying to confirm how to connect the equipment I already have (stock oil pump and Peterson dry sump tank).
Ken Roberts
Here is how the stock ls7 is hooked up. This is exactly how mine is connected since I'm using a modified factory oil tank.
Ken Roberts
I have a sneaking suspicion that the two sided mounted fittings are just connected in a loop internally in that Peterson breather can for convenience. If so......there are much cheaper ways of accomplishing the same type of hook up.
If the above scenario is true then just purchase a simple breather can like Grant shows. Then tee your two valve cover breather connections to the air intake tube (between the maf and t body).
