Paint Getting Close
Please let me start by saying that getting your GT40 painted can be a little like having a child, billions have done it before but when its your own its very special. I have a child and she does not compare to my care but I think you get what I mean.
So anyway I will share what I have done even though many have before. My car is to be based on the 1076 car from the 70's as I prefer no "moustache" on the front. It will have all the decals as well.
After the blue base was applied (not gloss as there is clear to be applied) my painter and I masked out the car. What a tough job. It took a day to get a stripe on and a few roundels!
Both front nostrils had to have the stripe and roundel applied in the same position.
The car height is way up to allow loading on the trailer. Panel alignment is only close enough for the stripe alignment etc. It will be adjusted further.
It all came out really well. Now I have decided, as with the whole car to do things different or take the hardest way possible so the following things were done:
- Gaps between the roundel and orange stripe would exists as per some images I have seen of original cars. Mainly though because I liked the look.
- Pin stripes were to be dark blue and painted.
- Roundels would be painted.
- The way stripes and roundels end on the panels would be different, I did not like running them through to the panel edges at the top of sills, under nostril panels etc.
- The twin nostril (only have it because at the time with Fran I could not decide what car I was doing) would be painted differently where the stripe is wider than the nostril.
Satin black inserts and colour sand is yet to be done.
Flares turned out really good. Many thanks to Kaber and Americar Auto for this.
The white paint for the roundels was chosen to not look to bright, I'm happy with it.
You can see the 12mm gap I wanted on the roundel. I love it, my painter hated it
. You can also see how I wanted the paint to stop before some edges. Not sure why but I like it, and my painter hated it
Credit needs to go to the painter, his patience and workmanship was first class in my book.
Roundels on the doors look great.
The blue and orange look great with the dark blue pin stripe. The colour formulation was a long process but it came out to my liking. I actually wanted them quite subdued like they may have been in the 70's.
Yes the single nostril is the one meant for the car but it may be swapped for the twin from time to time. The twin will make a good bit of wall art if I don't use it much! All up I'm very happy with it and with a colour sand to remove the peel and the decals it will look good. Just like others I have seen out there.
