Don't street race....you'll end up rapped around a tree, dead, and on fire.
No one said we were on the street...
I'm with Mike on this one. But I guess the video will prove/disprove it?
Put the video up Cody: It would make a huge change from Cars & Coffee (sorry Mike)..
I don't know about anyone else, but I'd love to see it...:thumbsup:
I'll be a bit generic, as there are obvious supporting mods that you would need to make in order for this to happen. Take say a late 90's Camaro, Bore x stroke it out to 6.8L (would require sleeving and replace the stock LS1 heads). Add a couple of turbos. You are at a very easy, and actually very streetable 1100 - 1200 HP. Strip the car down. Now you are at around 2700lbs. Put on some D.O.T street tires and a nice traction control unit.
Not saying it would be comfortable, quiet driving car, but it would be "in a straight line" as fast as the P1.
Cody's 441 LS7, would have at LEAST 600HP, and is probably closer to 700
P1 weighs in at 3280 and has 908HP giving it a
Power to weight ratio = 3.6lbs/HP
Cody's SLC probably weighs around 2400lbs and lets say 650hp
Power to weight ratio = 3.7lbs/HP
I say it's pretty close. Also, remember, the P1 has a 3.8L engine with two turbos, so it's trying to get 727HP out of a 3.8L or 191HP/Liter. The trade off is a little bit of turbo lag. Granted, turbos have come a long way since the 80s, and there isn't near the lag there was. However, I will say this.
Everything being equal and you have two identical cars with the only difference being one is turbo, the other is NA. The NA will be faster, as it does not have to worry about transient response and lag. Whereas you step on a turboed car, you have to wait for the exhaust gases to build up enough to push the turbine, which in turn pushes the compressor to bring in air.
Cody,
can you give us further details of the runs? starting gears for each run and finishing gear and/or speed each run?
Warren Kreyer used to own Cody's car and he told me the engine was dyno'd at 689hp, however, I can't recall the weight.
Yes, Warren built this car and he did very well. I just posted what happen because I was surprised and I wanted to see what other SL-C's are doing out there. I am not trying to brag by any means; I have no right to. All I have done in purchased a well built car and drove it. I have no reason to lie. I am surprised at the responses I am getting and all the negativity. I don't have a video because I was driving and I am not one of those guys that drive around with a GoPro on there car. I was out having fun with some friends (P1 and 918 drivers). Both the P1 and 918 drivers were just as surprised as I was.
Cody.
You beat a P1! A f*c*ING P-ONE!
I would brag all day long!
Outstanding cody!
I think everyone should take there car to the strip and show what they can do and post times and specs.
Does anyone else know any p1's or 918's to race?
Very cool, Cody! What speeds did y'all race up to?
F1 aren't doing too bad with 600hp from a 1.6l turbo (15k rpm). Hardly a street tune thoughno replacement for displacement except for maybe 10000 RPM
