Help with connecting my SPF A/C
I was moving the pedal box and managed to pull two wires off the A/C evaporator.
From Blas‘ wiring diagram they are for the A/C thermostat.
The proble is, the connector has 4 spades and I have 2 cables. I suspect it‘s the bottom (shiny ones) but I‘m not sure.
Can someone help me out?
No iI already looked there as well.
I know the 2 wires I pulled out (pink and purple/white). I just need to know which 2 of the 4 spade terminals I need to plug them back into. I guess the other 2 remain empty since I don’t have any other open wires lying around.
These are the wires btw
Have you tried contacting Rick Muck (Mark 1V) on this forum? My thermostat only has 2 terminals with the pink wire on the bottom.
Rick Muck- Mark IV
GT40s Sponsor
Yes, the shiny ones. And it doesn't matter which lead goes on which terminal as it is switch. And for anyone who needs A/C parts, I have most of a "take-out" SPF GT system available. Never had refrigerant in the system.
Thanks a lot Rick!
