Keith, Welded in on mine, makes them stronger but more of a pain.
Ben, yep essentially temp rivets. I'd never heard of them either before seeing them here.
You push down on the end of them (using special pliers), put in the hole and then release, it pulls it tight yet can be easily released by doing the same in reverse. Used AFAICT mostly in the aircraft repair industry.
You can do it without them but they do work rather better than the place the rivet in technique due to pulling the metal pieces together and of course can be used at any angle.
Anyway managed another panel tonight, took most of the time to make the template but now have 3/5 of the RHS/drivers inner wheelarch panels cut.
That is at least the hardest panels done, final two on the RHS should be pretty easy in comparison. It took me I think most of the time to make templates but now those templates should then be the same for the other side (plus I've already done 1/5 due to my mistake previously) but it'll still take just as long to fettle round welds etc.
