Desperate for Weber linkage help!
Gentlemen,
I am helping a friend w a weber 48 set up. The carbs were on the wrong side, canted too far, etc... We think we have it mocked up much better but I am not really able to find a "Go to" linkage vendor.
Mid engine of course, cable pull from behind the driver, need to pull a bell crank from 3 oclock at idle to the 12 oclock position so the the top arm going to pass side and bottom linkage arm going to driver side pull to WOT.
Can you guys recommend a vendor?
Many thanks!...
Brian Kissel
Beautiful Pantera Phil. Welcome to GT40S. If you could send a picture or two of your current setup, it would be easier to get advice. I probably can’t help, but others with something similar might chime in.
Regards Brian
Thank you Brian, this is my friends car, mine is not quite at this level...lol...
This is the pass side and the linkage rotates to the inside for WOT, as in the direction I am pointing. I need a source for a good strong center rotating bell crank.
