David Morton
Urs,
Congratulations to you and your Wife.
What are you calling her - Ursula?
Well done.
Daver M
Well done.
Daver M
Now i had a short brake in bulding the mono.
We get a little daughter3 weeks ago ! now i had a short baby brake
Yesterday we get the engine from Roush
It s a 427 IR and it s a real masterpiece.And it s amazing what you get for the price.
Today i place the bulkhead in the chassis and i laminate the inner side of watercooler pipe tunnel.Now we have to build the hinge points for the engine and the hinge points for the suspension tubes at the bulkhead.
The parts from Fran are also on the wayThank you!!
I have a 10mm PVC plate the Bottom has 4 unidirectional diagonal layers,1 layer to the length and 1 to the side and 1 layer diagonal Aramid,The side of the tanks has a armid kevlar layer with possibility to let it sightable. on the upper side of the bottom i have now two layers diagonal.Hello Uls,
Congrats on the baby, I just had my first late last year. Its good fun, but I think your free time to finish this tub will be significantly reduced along with your sleep!
I have some questions about the carbon tub project:
1. What is the overall panel thickness, and what ply orientation/weave are you using?
2. What are you using as a core material?
3. What are you using as an insert material for threaded holes and localized attacment reinforcement and load bearing plates?
4. What adhesive are you using to bond sections together?
5. How are you dealing with corrosion if you are using metalic inserts and/or core?materials, what is your expected lifespan for the tub?
6. Are you curing at room temp or in an oven or autoclave?
7. Are you changing diapers too?
Eric
What are diapers:thumbsup:
i think laminating is easyer than changing diapers.
And at last!! For the ultimate lightweight gt40 i will put in the allison turbine!!
