Hi all, hope all is well and everyone had a good Chritsmas. What is the desired front camber. Busy with my own home build frame, so using Vsusp calculator. Based on the mounting points I marked for myself I get to this
In a race car, Ackerman is largely academic. The tires are running at fairly large slip angles which defeats the whole purpose of Ackerman. On a street car it matters.It might be helpful to design in a range of adjustments instead of what the best guess might be as a final setting. As far as camber goes, you won't want it to go pos but might want to add neg. camber at some point. So I think if you can adjust from 0 to about -3 degrees you will be fine, especially with a predominantly street setup that you might like to take to the track in the future.
A good range for F caster would be from about 4 to about 7 or 8.
As far as Ackerman, antidive, and bump steer go I would try to adjust out any bump steer present at both front and rear and do my best to understand Ackerman etc. enough to compare to known good handling cars like a Challenge series Ferrari or a GT3 Porsche.
Ole is correct. You will find yourself making compromises. lots of compromises. A couple of things. First the longer the lower A-arms are the better off you will be, designing in as vertical a shock placement as possible, and again do your best to design out any bump steer as well as a low placement of the powertrain as possible and straight, 90 degrees to the centerline, alinement of the driveshafts.
Also. I would make the a-arm and shock mounting hardware simple to remove once the car is complete. Digging into the paneling to get to the through bolts so you can remove the lower a-arms is a pain in the ass. An example of difficult to work on would be the original lower front GTD and the upper shock mount on an SLC.
