OK, a search didn't yield anything concrete, so will ask a question. Did find some info from Bill Mussara (I think that was right) on an old thread from Chuck and Ryan that indicated his bolts were the same inboard and outboard. I have G50 transmission, went to install the half-shafts last night and the bolts there were supplied (still shrink wrapped in the box from driveshaftshop with not to torque to 57 foot pounds) didn't want to turn into either the flange on the G50 or the flange at the wheel. I believe the bolts are 10mm (.396 on the micrometer or so). When I looked at the threads on the bolts and the threads on the wheel end, it made me think that the bolts were standard pitch and the wheel end was fine pitch. Looked at the bolts and the threads on the G50 and it made me think the bolts were fine thread and the G50 was standard pitch. Found at least one reference chart that indicated that 10mm bolts come in three configurations (Standard, fine and extra fine, which I think was 1.00, 1.25 and 1.5). Hmm, that would explain what I think I am seeing visually.
I am heading to a bolt store today to get a bolt of each pitch to test the theory, but figured I would ask that question to see if anyone has run into this and can maybe confirm the bolt pitch at either end.
