Do you have a drawing you can share for the new center tunnel I would rather do that with mine vs making a cap.Swapped out center tunnels today. Slow and steady progress. View attachment 139294
Since I recently pulled my shrinker and stretcher out of the depths of storage. I believe I will attempt the gas pedal again.The two pads are a little tricky to make,but worth the effort as the throttle pedal is a nice piece
The "bulge" is mostly exactly over the center of the tunnel area. The stick out from the panel isn't as much as the pictures make it seem in the area the seat sits, with a bit of the right side for the passenger. The pulleys are mostly on that side.... so sucks for them....lol The driver side is pretty smooth. I have placed the spider on it with the dash, and setup some supporting material to sit on fir testing. I used some 5 inch thick foam for the back and leg area for testing and I fit with room. Not smashed up on the steering wheel.A lot of work done there…. Have you tried placing your seats? That bulge in the firewall will have you sitting up against the steering wheel, so unless you are about 5 foot tall with short legs you will battle to fit.
