Chasing an A/C leak
So I decided to go ahead and connect the a/c compressor and charge the unit , but before charging I checked if the system was able to hold vacuum and it was not . Howard suggested adding positive pressure , since the system was not charged ye, and I did , voila, the leak was very loud and easy to find, It was one of my crimps that was bad , only one !!
So I went to a local hydraulic shop and had the hose crimped professionally , since I do not own a crimping tool, I borrowed one the last time.
It sure looked pretty, so I connected everything , vacuum seemed to hold , then charged the system , and a massive leak on the newly professionally crimped hose, the only thing I can think of is that equipment is made for hydraulic hoses , it is probably a slightly different diameter than cooling hoses .
So finally ordered a professionally crimped hose with the right fittings and the right length, should do it this time .
Installed the hose, which was a major pain, now that the footbox is fully insulated. So note for future builders, troubleshoot your a/c hoses before you insulate your footbox.
So connected everything and vacuum would not hold at all, applied positive pressure and no leaks found , even used the black light stuff and nothing , no leak found . over and over I tried, no leak . What's going on?
I finally decided to try a new manifold and voila, the harbor freight special had a leaky gauge, very frustrating, now vacuum held overnight and charged the system one more time. everything works great now.
Moral of the story , cheap stuff breaks after a couple of uses sometimes. You get what you pay for. And sometimes professionally done does not mean better if not using the proper equipment.
Looking back I did notice that the gauge was acting a bit erratic with the readings , but I did not think about a leak
