Restarting my SLC project in West Texas
In July very cool visitors came to West Texas, Cam drove his SLC from Denver in 110 degree weather!!! What a friend. The SLC held up nicely and Cam did not melt. Howard also drove from New Braunfels for the SLC owners West Texas reunion LOL. How many guys does it take to finish a front hinge ???
It was amazing to see 2 SLCs in my garage. We had a great time !!! Ands lots of stories, Howard even played his guitar.
Hector and his family are some of the nicest people you would ever have the privilege to meet. I hope to go back and see them again as soon as possible. Cam made an epic voyage in his SLC. I wonder if that isn't the longest to date? Approx 1500 miles found trip.
Hector and his family are some of the nicest people you would ever have the privilege to meet. I hope to go back and see them again. as soon as possible. Cam made an epic voyage in his SLC. I wonder if that isn't the longest to date? Approx 1500 miles found trip.
Thanks Howard, really enjoyed the visit, we have to do it again soon. And I am planning to break Cam's record for the longest SLC trip. without using a tow truck or a trailer. :)
Next found a way to mount the windshield wiper motor, decided to go the bonded aluminum plates to the fiberglass route .
A recess was made on one of the aluminum mounting plates using a router and a mounting screw was also attached to the same plate and holes for the mounting tabs on the other. I figure there will be a lot of torque on the mounting plates as the windshield wiper turns back and forth.
I am way behind on my updates, here is a little progress
I did a little research on trying to maximize cooling while minimizing drag, making a very long story short , you want inlet area to be around 60% of the radiator core and you want the outlet area to be around 120-130% of the inlet area, therefore the outlet on the front clam needs to be opened quite a bit. There is also an area in front of the radiator on top that needs to be blocked to avoid air stagnation and vortexes formation. Howard noticed a marked increased in cooling when he blocked that area off.
1. use insulation foam to close the area in front of the radiator, I will glue it to the front clam later after the headlight harness is installed
2. Manufacture the intake duct. I chose to reverse the shield that came with the kit, never understood the original design. the fans push the air at close to a 90 degree angle , creating a massive amount of turbulent and reverse flow.
had to have room on one side for the fluid reservoirs and the a/c parts on the other.
Decided to create some air foils, to better direct flow and also to block the view into the duct
The air foils were curved on two different planes , I should have done straight foils like Allan does, but decided to get fancy, I believe that was a mistake, very difficult to accomplish with rudimentary tools and modeling clay, it is very difficult to Lay the fiberglass perfectly on a foil shape. the end results were cosmetically challenged but functionally acceptable.
Also added a little insulation to the duct surface
Also had to add an air foil the the rear surface of the opening I made so that the air would not hit a flat surface at a 90 degree angle
And here is the final product, again, cosmetically challenged but functionally acceptable .I tried to have the air foils follow the opening curvature, which was not easy at all. I am not too happy with the air foils so the opening will be covered with black wire mesh. Of note, the original opening remains intact and functional , so now there are 2 outlet openings . the outlet area is about 130% of the inlet area .
I am way behind on my posts , I will try to catch up a little
Next was the roof scoop duct, to direct air from the front scoop to the engine compartment , it also prevents water and debris from entering the cabin. Tricky to make for sure as it has to follow the roof curvature, fit between the roll cage bars , clear the small opening between the firewall and the roof and wider dimension at the front to cover the entire front scoop. Truly a fiberglass challenge.
I made the contour cutting some old foam pieces to follow the cage tubes, made myself a little wiggle room so that the duct will fit between the parallel roll cage bars. Used very thin sheet metal to form the floor of the duct.
I decided to bond it while the spider was hanging from the roof since I don't have my son Miguel anymore to help me flip the spider upside down. another challenge, glassing it in place upside down. But got it done.
I used a little bondo on the inside to keep all the surfaces smooth.
Finally painted the inside surface black so that it would not be visible through the front scoop.
I cut a hole on the rear clam for the clam to clear the transmission when fully opened , that meant the rear hinge had to be split in half and therefore the clam reinforced with extra layers of cloth fiberglass and an additional aluminum square tube. Hopefully it will hold .
After the spider was centered, then the rear clam was centered as well, aluminum spacers were made to keep the rear clam at the perfect position relative to the tires.
Next was the rear clam window and vents, the vents were straight forward , I ordered the standard ones, the finish looks standard but they are made from carbon fiber anyway, I'll take it, they are super light.
I was very nervous about cutting the plexiglass, as everybody knows getting spare parts takes forever, so I made a very detailed cardboard mockup , which was not easy due to the curvature.
At the end turned out really good, I won't take the protective plastic off for a while .
I used flat head recessed screws and JB welded weld nuts.
I just looked at the beginning of this thread, was started on May 19th, 2020. So I need to have the car at a a 98% or better finish by May 19th 2024, (meaning a few cosmetic details left, of course the car will never be 100% , right? ), and for sure must be driving on the street by then. So there, a firm commitment from me, my wife will be happy LOL .
It also means I have to hurry up and catch up on my posts as well.
4 years, Wow!! That is a long time. Thank you all for your support, this project would have been impossible without the awesome members of this forum. Cheers!!! Built not bought !!!
You're doing a lot better than I did, Hector! Got my kit Feb 2014, street legal Oct 2021, painted April 2024. Great craftsmanship as usual -- it's looking fantastic so far!
FWIW, the directions from Shields (who is/was the manufacturer of the parts) says not to counter-sink the holes .... I've always thought the trick to avoiding cracks in the plastic is a slightly over-sized hole and then cushion the bolt head with a rubber washer .... that's how I did my windshield using 4 #6s and it's been fine for 15 years. YMMV.
