David's Monocoque Build
Part of the motor mounting (2757). The hammer form is made up of 3/16 steel then glued to MDF with a thin coat of RTV.
Another part of the motor mounts. I formed the lower area first ( larger hammer form ) then removed the form , otherwise it would be trapped when the top was formed ( smaller triangle like hammer form). The blank was located and bolted on through the bolt holes required by the part.
looks great. This part really troubled me when i was trying to get it into Cad. You have done a fabulous job of recreating it.
2286 Reinforcement for the rear bulkhead and seatbelt mountings. This is a prototype, bends are rather close and this makes it a little tricky. I think I'll be making this from 18ga or 16 ga for the final part , it does mount the seatbelts afterall.
I think 18G or 16G would be how I would do it as well. Did you get this bent using a press brake, i have been thinking that i will need to get this part, as well as the center coolant tunnel done externally in a press brake?
I was able to make one bend on my press brake but the other bend was to close and would not fit in the machine. So after the first bend I clamped it down on on some steel bar and slowly bent it over that. I figure I'll get some 1 x 4 with the seam on the short side then I only have two long bends.
Where does that go David? I don't recognize what that is for.
looks great by the way. Keep up the good work.
Cheers.
Ryan
Cheers.
Ryan
Thanks Ryan
It goes across the top of the battery to hold it in place and I believe the two larger holes allow the battery vent caps to poke through. Only seen two or three photos of this part.
It's amazing how you can spend 1000s of hours looking at these things, and still miss details!
I bet I start noticing that bit all the time now.
Ryan
Ryan I took another look through my Mk1 photos and it looks like only one on 1013 , others may have it installed but with the fiberglass battery cover on can't see. Another thing about it is with battery problems I can see this part not put back on or easily lost.
James,
Thanks for the excellent image, another angle I had not seen.
Do you know what chassis number that is?
2033-2039 Assembly Reinforcement Door Rollbar . Some of the smaller parts are the most difficult to fabricate .
