TIG WELDING TIME WITH TANK SIZE
Adam C.
GT40s Sponsor
I keep TWO 125’s on hand at all times.
It is not uncommon to go through one in a weekend.
I would have 300s, but they require a lease contract.
Usage rate depends on if you are using a gas lens or back purge.
While learning to TIG you will be very slow and you will go through a lot of gas.
Short answer is go 125 or larger right out the gate.
I went through what is said to be a 55 cubic foot tank in 3.5 - 4 feet of practice welding, is this to be expected or do I have a leak. My MIG tank is the same size and have used 4 pounds of wire per tank, even with the post flow I expected more.
Adam C.
GT40s Sponsor
Yeah it will be hard to do much more than strike an arc with a 55.
MIG is usually ~3 cfh while TIG will be 5-10 without a lens, or 20-30 with. Back purge will be ~3 for a stainless header primary (continuous!)
Your gas supplier should let you trade up no problem.
I got a used 300 with my TIG and went through 2 full tanks with the majority of making my chassis with mostly a gas lense. I did find I went through the second bottle significantly faster due to using a longer supply hose (standard was 4ft vs 25ft) when I needed to work across the shop but not move my large bottle. Not sure how many hours of welding but it was a few LOL. IMO go with the largest you can find & handle. This one is really heavy and there may be a day when I get older that it will be too large for me to deal with.
I have just signed up for an introduction to TIG welding course at the local Tafe, so I suspect I am about to use a bit of this gas as well :)
Thanks for the reply's guys.
Spring of 2024 the 55 cubic feet tank cost $55 CAN to fill, now September $65 the 110 cubic feet tank cost $75 for the fill. So it will be expensive to learn but when you run your first aluminum weld it is very satisfying.
Another consideration can be tank weight. I can't move around the 300s anymore. I have a 125 and it weighs about 60-70 pounds. The 300s were twice that. Also don't buy a tank that you intend to keep and refill. An exchange program with a local welding supply where you simply exchange your empty tank for a different but same-size filled one is a much better way to go. You will never have to recertify tanks that way.
How big? I have no idea how much you intend to weld. Having said that I think I still recommend a 125 and if you need more gas on hand then just get a second tank. I believe you can return the second tank at the end of a big project to the welding supply store, Ask them. This will keep the weight per tank low and still keep enough gas on hand,
For example, I tig-welded a complete set of headers for my SLC with a full 125. I also welded all my water pipes together for the SLC and back-gassed them (stainless requires back-gassing and more gas) with a full 125. My most recent project was a new set of steel engine mounts for my SLC. I started that project with only 500 lb/inch in the tank, and it was fine. They hold more than you think.
So my vote is a 125 unless you have a commercial requirement. Find a welding supply store and go in and ask about exchange tanks and available sizes. Where I live the 125s and 300s are the common sizes. You want to be able to take your empty back and exchange it the same day when it runs out.
