SPF GT oil and water gauges
Can an SPF owner confirm the following please:
1. Water and Oil Temperature gauges are mechanical with thread-in bulb-type sensors
2. Oil pressure gauge is mechanical with a plastic hose with thread-in flare fitting
Have you used a T fitting for the oil temp and pressure or used different block locations
thanks
Can someone confirm if SPF supplies these with nylon tubing. I don't have the car and will replace nylon with braided stainless if that is the case. thanks
