Restarting my SLC project in West Texas
Well if you want the short answer the hot cat was created by an exhaust leak caused by a broken bolt and absence of donut gaskets between the exhaust manifold and the mid pipe , excess Oxygen , I guess .
I created another thread with the full story and the mystery solved by Howard .
Neil
"...the hot cat was created by an exhaust leak caused by a broken bolt and ..." I'll bet that broken bolt was not made by SPS or Allen. There are a lot of junk fasteners out there, counterfeited to look like high-quality stuff. If your application is critical, depend on high grade industrial or aerospace fasteners!
Well, in the mean time, while working out frustrating engine or mechanical problems, I was also working on less stressful stuff, how about leather wrapping my freshly made center console components. I decided to add a little foam for my right elbow , since I am getting sensitive in my old age. LOL . I have enjoyed learning about upholstery . Leather stretches A LOT , and it makes it easy for beginners like me. Super happy with the end product
Well, I heard horror stories about melted cables , so I decided that anywhere a wire or cable approximates any exhaust components I made a micro louver shield. Thanks to Aaron Hamilton to help me secure the last sheet available anywhere , in Perth Australia. I don't know why they quit making it, the stuff is awesome , very effective , and easy to work with
Before I knew there was an oil temperature and level plug that the factory harness does not use . Why ??? (yes the one I plugged the crank sensor into ) . I came up across a connector that fits into the AIMS Strada unit . probably overkill, but Oh Well , can't never have too much information.
I decided to upgrade to stronger springs in the front and stronger longer springs in the rear, and might as well upgrade to metal bushings along the way . Also added the bearing that makes it much easier to adjust suspension height and spring tension. Thanks to Cam for the tips .
Neil
Your experience reminds me of a book I ran across in the library back in college. "Human Factors Engineering", it covered how to make as fool-proof systems as possible by covering a very wide range of subjects. One part that I was reminded of was to never use identical connectors where a cable could be plugged into the wrong one. Their rule was to use different connectors for each connection. Sometimes the connectors may look similar but internally they have an index key in a different position so a wrong cable connector cannot be plugged in.
Neil
You will love those radial needle bearings!
So time to kick the interior into high gear. Start with the tub . I keep reading about fuel sending units going bad and the need for an access panel. both on the tub and the fuel cover. , so now is the time !! kilmat everywhere how about foam for noise and insulation purposes and carpeting for a nice finish . How hard can it be , right?
And don't forget the speakers, I found super thin small ones that will fit and still pack a punch . Morel virtue nano 603. https://www.crutchfield.com/S-nUDxp7FlLtJ/p_210VIRN603/Morel-Virtus-Nano-603.html
I've only ever blownout the rear shock mount eyelets, then I replaced them with the steel ones. I suspect it was because the springs were coil binding or the shock was bottoming. Never investigated to the level of confirmation. Your longer springs will help the coil bind question and the steel will prevent eyelet failure. Still its a good idea to wrap a zip tie around the shock shaft to see how much travel you are consuming under compression once on the road in earnest. Once the ideal shock/bellcrank angle has been established, my preference is to adjust the ride height with the pushrods.
Those needle bearings are the "dizzle" :)
Well since the tub was out , it was time to tackle one of my pet peeves about the SLC interior, those super wide butt ugly A Pillars. I had bought a hydraulic kit a year ago. Time to use it . Scott had paved the way on this project, but I was way over my head on the amount of force that takes to gently bend the front part of the cage , and of course it needed to be lengthened and new flanges welded, It took forever and a lot of creativity including a tree stump.
When you are bending the front hoop, there is no way to make sure both sides get bent evenly, so to fine tune things a good ol tree stump on my backyard saved the day . Super happy with the end result . Much harder than I anticipated though .
I have not taken a final picture , the gap is a bit smaller on the passenger side .
Happy my shoes have thick soles. I stepped on a wedge I cut out of a steel rod. Close call to a major burn .
Thank you so much, that is a question I had about adjusting ride height, I was aiming to keep the adjustment thread half way on the coilovers and then use the pushrods for final adjustment, Thank you very much for the tip .
well I noticed that the carpeting was getting worn out around sharp edges, so decided to extend the floor mats all the way to the seats . originally I only had a small floor mat next to the pedals. The openings are for the side cage mounting . The eagle claws will hold the mats in place nicely since I have full thickness insulation under the carpeting inside the footbox
The fuel sender calibration was a major PIA, adding fuel 1/2 gallon at a time, to create the calibration table . I used a converter to change the signal from 0-100 Ohms to volts so that the AIMS Strada unit can read it.
According to my calculations at about 14 1/2 gallons the fuel starts flowing into the filler hose elbow, which makes me nervous , considering all the moving pulleys and belts near the rubber elbow . I went up to 17 1/2 gallons . Curious to know how much you all fill your tank and what is your experience with the stock fuel sending unit that came with the kit .
So far, the fuel splashing when the tank is low makes the unit a bit crazy . Either way , happy to have fuel sensor working.
so after much going back and forth, and considering I have gold wheels, I settled with the John Player Special black with gold accents look, which also matches my interior carpeting and seat colors .
I will have to paint the gate for the shifter and shifter rod black . The center console center face will be gold color instead of black , probably leather, the wrap I had used did not hold up at all.
Blingy golden shift knob, hopefully I won't forget where reverse is LOL
So I drove over my neighbors house and dumped a bunch of coolant on his driveway . The rubber hoses that came with the flexible radiator hoses that I used failed miserably , replaced them all with silicone hoses . Had to re do all of them, , was a mess and a royal PIA , better on my neighborhood than on the road. Cant catch a break.
I ordered the morimoto lambo style sequential corvette tail lights, trying to decide what to do with the reverse light
I forgot to mention that I did melt a shifter cable, but not because of poor insulation, I failed to secure it properly and it touched the bottom of the mid pipe . FYI the heat melted the triple insulation . Bottom line don't let the cables touch hot surfaces, even if insulated properly. Shifter cables now properly secured , the area where they are right next to the catalytic converter is holding up well . I did have to replace one shifter cable though. Not happy about that .
Well, I love my comfy seats, but my son Miguel , now 17 , has grown a lot and he has a long neck, will have to dust up the original fiber glass seats or get some Tilton ones, so he can fit . I figure ai can swap them occasionally, not a big deal.
