Chris Kouba
If one were going to make model(s) of the GT40, I presently believe there are only 2 variations of the Mk I and Mk II. Is this accurate?
My recollections are as such:
The classic, original Mk I bodywork, no rear flares, twin nostril nose panel, small driving light, turn signal in lower nacelle:
Stacked tail lights:
You can start to see that the vent cover panels aren't necessarily standardized on the rear of the car and on top of the rear clip.
The classic Gulf bodywork, single nostril panel, big lower driving lights:
single tail lights, vents cut out in the corners of the rear clip (above tail lights), 9-hole vent in top of rear clip (hard to see):
No covers in the back panel
Chassis 1015 (1966 bodywork), it does have higher front arches than the Mk I, developed for Daytona, right?:
From the back, stacked tail lights but different than the original Mk I lamps:
The Mk II's were pretty consistent regarding tail panel treatment, I think. Just variations of the rear vent cover (between the periscopes)- was clear at one point (at Le Mans I believe, because the ACO said they couldn't see well enough out the back). Sound right?
Mk IIB:
The visual difference is the in front of the front wheels and behind the lower nacelle:
Compare that pic to the one of 1015 above. The bodywork moved outward and downward to push air around the wheel wells for 1967. Any other differences that a curbside model would need to exhibit to be accurate?
Does this all sound about right?
Mk IIB:
