January 10, 2015
Working the front clip
The Guides are now in place and I decided that the back side of the clip needed additional support around the latch area. Since the SARMA latches are cut into the latch recess, clip is weakened in that area. I cut some aluminum angle to form a cavity behind the slits cut for the latch. I used my hot-glue gun to “tack” the angle in place, then started laying in the Everglass.. The pictures don’t show the finished product, but I wanted to get an update done to this log tonight. I’ll post more updates later.
Okay – all that is ugly – but I will straighten it all out…
Next up is to get the center clip fasteners (Dzus) holes drilled in the clip. Okay – so how do I figure out where to drill the holes? I have already fastened the steel mounts with Dzus spring. I needed a transfer punch to mark my center.
I took a 3/8” bolt, sawed off the threads and turned the head down to a point in my lathe. This transfer punch fits in the hole for the Dzus button. I'll put some tape on the clip and push the clip down onto the transfer punch. Easy stuff now – just drill a pilot hole where the transfer punch mark was left.
