Ken Roberts
So nice and clean...
All looks great Ken... :thumbsup:
Car's looking really good. I can't wait to see how your interior turns out. I really like your third brake light and side marker lights.
I thought I had a sign that an SLC was in my near future. I was in the junkyard looking for some parts to complete a project and I spotted a Taurus wagon with a white third brake light off in the distance. I was going to get the first part for my SLC! Alas, the car was completely burned on the inside and I couldn't figure out a way to open the hatch to get it off. That's the way I roll.
Ken:
Let us know how the 750 lb springs look. Are you using 7" - 750 lb? I'm getting ready to order mine and I want to see examples before I order. Your transmission is heavier than mine? How much more weight?
I'm coil bound too.![]()
Great suggestion.Here is an important modification that all builders should consider.
My solution was to weld the bolt heads to a flat plate. This plate gets bolted in place from the bottom with 5/16" allan head bolts.. The bolts won't spin because the heads are welded to the plate.
