Congratulations Jim. Beautiful car... Is your garage built for a motorcoach ?
gas tank will be removed again and was just but in place for mock up for mounting brackets that need to be fabricated.
- did you get much slag/al shavings out of the gas tank? I notice the sterring rack now comes standard with an angled steel bracket. hmmm. Looks sweet, sounds like you will be ripping thru the build...
Hi Jacob, I'm glad that my car could play a part in convincing you to go with a SL-C. I like helping other people spend their money!:evil:Looks like you are off to a great start Jim!
I also had the chance to see your car before it left RCR when I got a shop tour back in June. Thanks to its mostly-assembled state at the time, it was very instrumental in thoroughly convincing me that the SLC is the route I wanna go
Jimmer,
Try to reduce the matrix size of your image, maybe 640 x 480 or so.....
Doc
Jim,
the reservoir should be mounted higher than the pump...many builders mount the pump as low as possible , essentially on the floor of the radiator box...making it a non issue to have the reservoir higher.
