Gearbox linkage : from rods to cables
Hello everyone, new member here from Biarritz, France !
I am a junior motorsport engineer/mechanic currently helping my dad during my free time in his workshop dedicated to classic cars.
He owns a Ford GT 40 since years (MkI from 1969, right hand drive, gear lever on the right) but doesn't have so much time to take care of it, so I decided to give it a try.
The main problem here is that he would like to change the gearbox (Renault UN1) linkage swaping the rods system to a cables one, because with the current system the gears are in the wrong way (1st gear on the right).
I saw some informations on other forums about adapting linkages from other cars like Mazda mx5, Toyota e90, etc, but didn't find anything specific or detailed.
He already bought a linkage system from a Toyota e90 (cables are too short but lever positions are matching), I don't know what could be the better option, adapting the Toyota system with longer cables and making my own shift system on the gearbox's nose, or going a total different way with your ideas if any of you already made this kind of modifications.
Thank you in advance for your answers !
Welcome to the Forum.
UN1 with right hand drive and right hand shift is perfect for a rod change and it is fairly easy to do and you end up with a H pattern shift.
left and back is reverse
half left and forward is first
half left and back is second
forward is third
back is fourth
and right and forward is fifth
I will track down some photographs and post them
forward is third
back is fourth
Thank you for your answer ! Can't wait to have a look at the photos !
Yon, repeat - You do not want to change to cables !
fitting rod change correctly is a very simple job, perhaps you should send some pictures of your existing system for us to see.
It may be an option, didn’t find a solution with rods adaptation during my researches but some of you may know one. Here are some photos of the whole linkage system :
Here’s a photo of the rod change on my GTD GT40 designed, made and fitted by Frank Catt. No stirring a wooden spoon in a bowl of custard for me but clean crisp changes up and down, especially 3rd to 2nd. Beats cables anytime.
Here are some pictures of the DAX gear change when being set up
The rod end was moved closer to the chassis rail mounting the gearstick further to the right than shown in the photo
The rod then runs straight back along side the fuel tank and through the firewall, where it attaches to a universal joint and the rod moves inboard to the front of the gearbox and a second universal joint where the rod then runs direct fore aft.
Lastly everything connected and standard H gearshift
Now I heard of someone in Australia who made a rod gear change and instead of the rod end and pivoting at the front did that in the same way a rifle bolt works.
This could also be done for the Renault box but you would have to work out the movement at the rear….. I believe the first arm on the gearbox instead of being mounted downwards would need to be mounted upwards to retain the standard H change
Neil
Transaxle shift linkages in a mid-engine car can be difficult. Here is how I did it with a Porsche G50 5-speed transaxle (not a GT40, though). I used Thompson ball bushings and Case 60 shaft. This geometry preserves the conventional 5-speed shift pattern.
Shift linkage G50  Newest 1.jpgShift linkage G50  Newest 5.jpgShift Rod Bearing 5.jpgShift Rod Bearing Housing Rear.jpgShifter Swinging Link.jpg
