Coolant hose routing on SBF Ford... How'd you do it?
RCR 40.... Curious to see pics of hose routing between engine and long tubes, as well as reservoir/overflow can....
Joe, it’s very difficult to show clear routing photos because of the tight and congested spaces involved. Here are a few that may help.
Also included a photo of my expansion tank, but again, not easy to understand the hose routings. The upper left fitting is the vent line from top of radiator and steam relief from rear of heads. Below that is the rubber hose to the second water pump outlet. Underneath the tank is the 1/2” AN line that connects to a tee going into the water pump inlet. The upper right fitting obviously goes to the overflow/recovery tank.
Michael, what a great idea I’m stealing for the drain petcock location! If able, I’ll tilt mine down as far as possible (albeit clearance issues) to aid in a clean draining process.
Has anyone tried or have negative thoughts on having an under engine cover to aid in a smooth belly pan?
I had a SS belly cover on my car when I got it, but it was way too heavy and I removed it. A lighter weight aluminum panel would be a better choice IMO.
Thanks Michael. Looks like a combination of 90 degree hoses and couplers for the large hoses. I assume you just buy random sections off the shelf that will fit and couple them together? Also, any pics of the upper intake fitting ( looks like 90 degrees)? So the smaller water pump fittings just go back and forth to the expansion tank? Thanks so much for the info!!
Joe, I actually utilized a variety of 90s, 45s (some with 4” legs, some with 6” legs) and straight sections, plus you’ll need several aluminum couplers all of which are available at Pegasus. You can pretty much do everything with those OTS pieces.
The upper intake fitting is a billet aluminum swivel unit, which makes it far easier to route the hose.
The upper water pump fitting is for the t-stat bypass hose, the other goes to the expansion tank.
Paul Walton ran an aluminium belly pan on his Tornado GT40
Things did get hot and from memory he lost his speedometer as the sensor got too hot
Changed the rear 4 hole Le Mans style vents for MK2 type mesh for more airflow
He also started making some naca ducts to channel air towards things like alternator, fuel pump etc….not sure how he got on with that
I just worked through this on my SPF:
I have some left over unused couplers, silicon hoses, and Gates power bands for a deal...but they are 1000 miles away and are a few months from being visited. If your project timeline allows it and you are interested...
So ive gotta ask, whats under the lexan window? I assumed thats where the battery goes, but i could be wrong....
Hi Mike, what fittings do you have left?
I don't have a specific list on me right now, and, as mentioned, I am quite a distance away. I can try to look at purchases and derive a approximation though...
I had enough to change to all silicon with metal couplers. I ended up buying the big steel pipe from Hillbank and used that instead.
I know I have some (probably 6) Pegasus
HJ4545mm (1 3/4 inch) Pegasus Pro Design Aluminum Hose Joiner
And I am guessing a couple of 1-3/4" silicon 45s and maybe a 90 degrees. I also have two 5/8" silicon 90s. Then there are a bunch of Gates PowerGrip 32954 and 32925 and probably 32948 Hose Clamps...
